ACS 4.2.0 AAA-server-IP-address changing to 169.254.x.x
Feb 22nd, 2010
I have ACS 4.2.0.124.15   installed on a windows server 2008.
In the configuration menu : network config > AAA server , the AAA-server-IP-address change to 169.254.x.x each time I disconnect the  ethernet interface of the server.
Allthough, the ip adresse in my network connection of the windows-Lan-connection is set to static.
Whe I reconnect the ethernet interface of the server, it stays in 169.154.x.x.  And I need to reconfigure the real static adresse each time.
Do you knows this problem. Is it a way to avoid it ?
Michel Misonne
Ganesh Hariharan Mon, 02/22/2010 - 03:09
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Michel Misonne
Hi Michel,
It was issue in ACS 1113 SE Appliance and clear solution for the above is mentioned in the below link
http://www.ciscosystems.com/en/US/products/sw/secursw/ps2086/products_tech_note09186a00808d9199.shtml#stat
Ganesh.H
