WLC 5508 : session disconnected when one lag-port is down.
Feb 22nd, 2010
I have a WLC 5508 ( version 6.0.182).
When the port1 and port2 are connected ( The switch is configured with a etherchannel in forced mode) everything works fine: There is traffic on the 2 ports.
When I disconnect one of the 2 ports, I can still ping outside with my PC client, but all my tcp sesssions goes down and I even cannot restart my session. The only way I found  is to do a "Disconnect / Reconnect"  on my  PC  wireless connection.
Do you know this probleme ?
Is it a way to avoid it ?
Michel Misonne
dselfridge Mon, 11/15/2010 - 06:29
Hi Michel,
I have the very same problem (ver 7.0.98).
Did you get anywhere with this?
Kind Regards,
Dan
mmisonne Mon, 11/15/2010 - 07:38
Hi Dan,
Unafortunately, I didn't try since that time.
Please tell me if you get any information about this.
Michel
Nicolas Darchis Mon, 11/15/2010 - 23:27
  • Cisco Employee,
CSCth12513 LAG fail-over does not work on CT5508
This bug is fixed in the special release available through TAC : 6.0.199.157 and 7.0.xxxx
Hope this helps.
Nicolas
Dont' forget to rate answers that you find useful
