catalyst 3560 Gig port
Answered Question
Feb 22nd, 2010
hi
i have a catalyst 3560 48 port switch with (4) sfp ports ,am trying to connect the Gig port of this switch with another cisco swtch 2960 over a distance of 1000m (two seprate buildings using SM fiber cable) ,first i make a loopback on the same port locally ,but it was not succesful ,what seems to be the problem? ,if you can advise about the module type compatible with my switch ?
appreciate any suggestions
thanks in advance for your help
Correct Answer by Ganesh Hariharan about 6 years 12 months ago
hi
For connecting over a distance of 1000m between the switches 3560 and 2960 switches check for the transreciever GLC-LH-SM which can support
1000BASE-LX/LH SFP transceiver module for MMF and SMF, 1300-nm wavelength.
Check out the below link on the same Hope that help !!
http://www.cisco.com/en/US/docs/routers/7200/install_and_upgrade/gbic_sfp_modules_install/5067g.html
Ganesh.H
Overall Rating: 5 (1 ratings)
Jon Marshall Mon, 02/22/2010 - 03:26
jamelataher wrote:
hi
Jamila
See this doc which lists all the gigabit transceivers that can be used with the 3560 -
Gigabit ethernet transceivers
Jon
Correct Answer
Ganesh Hariharan Mon, 02/22/2010 - 03:53
hi
Ganesh.H
jamelataher Wed, 02/24/2010 - 01:30
dear  jon   & Ganesh.H
thanks a lot for assisting me ,i dont have the type that is compatible with my switch ,i have orderd it and will try again when i receive it ,
hope you all the best
jamela
