ACS5.1 with RSA Identity Store
Feb 22nd, 2010
Hello togehter,
I eval the ACS 5.1 Server with an RSA-Token-Server. All works fine. But now I want to use the RSA-Groups in the ACS-Server and I can't find where I can use it. Is their a way to use the RSA-Groups in the ACS-Server?
Kind regardes
Torsten Töben
jrabinow Mon, 02/22/2010 - 06:12
  • Cisco Employee,
Can you please clarify what you means by RSA groups. What are these, where are they defined and
where do they get returned to ACS
t_hesse Mon, 02/22/2010 - 06:23
Hello, no problem.
In the RSA Server I can define groups in which I put our RSA-Tokens. These groups I want to use in the ACS-Server for authentications.
I hope that would help you.
King regardes
Torsten
jintao99 Tue, 06/01/2010 - 10:50
Hi Torsten,
Have you found the answer yet? I want to do the same thing.
Tao
t_hesse Wed, 06/02/2010 - 01:49
Hello Tao,
no I didn't find an answer until now. But I found a workaround. You must aply the RSA-User also local in the ACS. Then you can group the user in ACS. The User will then be authenticated against RSA an authorizated against the ACS group.
Regardes
Torsten
