02-22-2010 06:13 AM - edited 03-06-2019 09:49 AM
I have a 3560 switch newly installed and have created a mgmt VLAN (999) but the line prot is down and won't come up
Vlan 1 is shut down and 2 other vlan's exist Vlan 2 (user data) and vlan 700 (voice) which work fine
Users are plugged in and working, vlan exists in vlan.dat etc
What am I missing?
config attached
thanks in advance
Jonathan
Solved! Go to Solution.
02-22-2010 06:45 AM
What am I missing?
config attached
thanks in advance
Jonathan
Hi Jonathan,
It is because of Autostate is implemented on CatOS and IOS Cisco based switches by default. On some CatOS platforms, this feature can be disabled in order to allow redundancy in special scenarios. On IOS based switches, this feature cannot be disabled.
The router VLAN interfaces have to fulfill the following general conditions to be up/up:
* VLAN exists and is in active status on the switch VLAN database.
* VLAN interface exists on the router and is not administratively down.
* At least one L2 (access port or trunk) port exists and has a link up on this VLAN. The latest implementation of the autostate feature allows synchronization to Spanning-Tree Protocol (STP) port status.A VLAN interface will be brought up after the L2 port has had time to converge (that is, transition from listening-learning to forwarding). This will prevent routing protocols and other features from using the VLAN interface as if it were fully operational. This also prevents other problems, such as routing black holes, from occurring.
* At least one L2 (access port or trunk) port is in spanning-tree forwarding state on the VLAN.
Hope to Help !!
If helpful do rate the post
Ganesh.H
02-22-2010 06:20 AM
Hi, you need to assigne at least one device to this vlan to make protocole up.
02-22-2010 06:21 AM
Atleast one interface you need to assign to this vlan(999).
Then only this vlan wil comes up.
regards
karuppu
02-05-2020 11:29 PM
02-22-2010 06:45 AM
What am I missing?
config attached
thanks in advance
Jonathan
Hi Jonathan,
Hope to Help !!
Ganesh.H
12-03-2021 02:43 AM
Hello Ganesh,
This was so helpful.
Azhar M
08-23-2022 02:33 AM
Thank You. Once I assign the VLAN to access or the Trunk Port. The Protocol converts to up.
11-22-2017 08:34 PM
Hi folks,
Am having one doubt,in cisco packet tracer of model 2900 series router has vlan,but line protocol is down,please help here how to make it up,(we know in switches by assigning one link up interface to the vlan makes line protocol up),this is router right?
Please help here.
T.Manoj kumar
07-15-2021 10:40 AM
i hv same issue ...Vlan10 is up, line protocol is down .
CSS2#sh run int vlan 10
Building configuration...
Current configuration : 88 bytes
interface Vlan10
ip vrf forwarding BEARER
ip address 172.1.1.2 255.255.255.252
end
CSS2#sh run int fastEthernet 1/0
Current configuration : 73 bytes
interface FastEthernet1/0
vlan-id dot1q 10
exit-vlan-config
end
CSS2#sh version
Cisco IOS Software, 3700 Software (C3725-ADVENTERPRISEK9-M), Version 12.4(15)T14, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 17-Aug-10 12:08 by prod_rel_team
ROM: ROMMON Emulation Microcode
ROM: 3700 Software (C3725-ADVENTERPRISEK9-M), Version 12.4(15)T14, RELEASE SOFTWARE (fc2)
07-15-2021 12:21 PM
Can you try this configuration instead:
interface fa1/0
no vlan-id dot1q 10
switchport mode access
switchport access vlan 10
11-08-2021 01:39 PM - edited 11-09-2021 07:42 AM
What if I want to have a VLAN dedicated for management? A VLAN which exists on the switch but has no ports in access mode?
I would connect to the VLAN interface from a pc connected on another switch.
PC1(VLAN10)<->(VLAN10)SW1(VLAN99) <-> SW2(VLAN99) <-> MGMT PC(VLAN99)
