how to monitor multicast MoH in SRST for IP Phone
Feb 22nd, 2010
I implemented multicast MoH in SRST router and want to know any way to monitoring the multicast MoH status in SRST router for IP Phone
-I can monitoring the status when a call from PRI interface with command "show ccm-manager music" or "show voip rtp connection"
-when SRST site IP Phone receiving multiscat MoH traffic from SRST router, I can check the status from RTMT or sniffer on the IP Phone but I want to know how to check the status from SRST router.
Advise please,
markbatts Thu, 02/25/2010 - 08:32
  • Bronze, 100 points or more
Have you tried
debug ephone moh.
cheers
mark
Please rate useful posts
Christopher Newton Thu, 03/04/2010 - 13:59
Also try a "show ephone summary"
this will verify that the IOS software was able to read the audio file, see example below.
File music-on-hold.au type AU Media_Payload_G.711Ulaw64k  160 bytes
If you see "INVALID media" then an error is present.
Hope this helps.
Chris
