(lms3.2) Devices discovered but unreachable?
Feb 22nd, 2010
I recently installed lms3.2 to a newly installed cisco network.  When I run device discovery, all my cisco devices are displayed as unreachable.  What could be causing this issue?
Thanks in advance
Joe Clarke Mon, 02/22/2010 - 09:42
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Make sure you have configured the correct SNMP credentials within Discovery Settings.  If you are using a mix of SNMPv3 and v3c/v1, make sure you have configured fallback (if appropriate).  Check the devices' configurations, and make sure the LMS server is allowed to poll the devices with SNMP.
roderickmcdonald Mon, 02/22/2010 - 10:04
Thanks for the reply,
I checked the snmp credentials and they match on both the lms platform and the switches.  I could view and configure any devices in the chassis view.
Okay, I re-discovered my core router successfully, and the device as been added to RME devices.  But, sys inventory polling and collection jobs are failing, what could cause this issue?
Rod
Joe Clarke Mon, 02/22/2010 - 10:05
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Post the IC_Server.log.
Joe Clarke Mon, 02/22/2010 - 10:11
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
NMSROOT/log where NMSROOT is the path into which LMS was installed.
roderickmcdonald Mon, 02/22/2010 - 10:21
Quick question:  Is there a way to input an ip address range in the snmpv3 target text box under device discovery?
Joe Clarke Mon, 02/22/2010 - 12:49
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, you can put wildcards or ranges in the Target field for SNMP settings.  See the context-sensitive online help when adding a new target for the syntax.
Related Content
