pound key to bypass T302 timer problem
Answered Question
Feb 22nd, 2010
Hi All,
I am using CUCM 7.1. When I dial international number then press pound key to bypass T302 timer, I receive busy tone. But when I wait for 15 sec, the call is successful. is there any service parameter in CUCM to allow dialing # key to make a call immediately?
thanks
Alex
Correct Answer by Eldho E Kuriakose about 7 years 5 months ago
U have to create another route pattern with 9.!#
Overall Rating: 5 (1 ratings)
paolo bevilacqua Mon, 02/22/2010 - 10:53
  • Hall of Fame,
    Founding Member
Why don't you change interdigit timeout to 3 or 4 seconds like most people do ?
alex goshtaei Mon, 02/22/2010 - 10:58
thanks for your response. But I need to use #, since most people get used to it.
paolo bevilacqua Mon, 02/22/2010 - 11:09
  • Hall of Fame,
    Founding Member
I think a good installation has both reasonable timeout, and pound termination.
Then, some countries use fixed lenght numbers, that you can configure if dialed frequently.
david-lima Mon, 02/22/2010 - 12:02
  • Bronze, 100 points or more
Hi, just a suggestion, do you have a route pattern with the # symbol at the end, for example: 9.!#
hth
David
Correct Answer
Eldho E Kuriakose Tue, 02/23/2010 - 05:39
