I have a Linksys SRW 2024 switch but no serial cable, how can I get/buy one?
rvhelvoort
I bought My SRW 2024 on the internet, it is delevered to me without the serial cable. How can I get/buy such a cable?
I need the cable because I made a mistake and the switch is not manageble by web because of that any more. The management is connectet to a vlan where no ports are connected to any more.
Thanks for helping.
3 Accepted Solutions
Glenn Quesenberry
I would recommend contacting your distributor/vendor for a cable as one should be included with all valid orders.  Barring that any standard 9-pin (DB9) serial cable that could be purchased from an electronics dealer such as Frye's Electronics, Micro Center, etc. should suffice.
Best Regards,
DJX995
Level 3
Level 3
Yeah, it definatly should have come with one.
However, I believe the SRW has a male serial port on it.
So, if you wanted to pick a serial cable up your self, it would be a straight through female-female serial cable (as opposed to a null-modem serial cable).
Hey team,
Here is a similar link by 'Super Dave':
https://www.myciscocommunity.com/message/33923
If you have a pair of the db9 adapters, you can try a straight cable in between.
Another link, might also work ...:
http://www.diablocable.com/linksys-srw-224p-console-cable.html
HTH,
Andrew
5 Replies 5
Glenn Quesenberry
Best Regards,
DJX995
Level 3
Level 3
Hey team,
HTH,
Andrew
rvhelvoort
Thanks.
I bought a cable on a local cablestore.
I can mannage my switch again, and fixed my own mistake.
Fantastic news!  Take care.
