Unity connection migration
Feb 22nd, 2010
Howdy,
I'm intending to migrate a Unity connection 2 server to another box. If i do a backup first will i be able to restore all the data and greetings for each mailbox on to the new server?
Taff
Tommer Catlin Mon, 02/22/2010 - 13:38
Yes, DRS will will restore everything.  Just make sure you rebuild the server with same hostname, IP address.  Also use the same restore point you used to backup.  I heard there was an issue if you used a backup point, then used a different point to restore.
p-siadoua Thu, 12/02/2010 - 06:33
I have tried to rebuild my unity connection 7.0.1 box on a VMWARE machine to test my backup files. But the restore failed at 67%, i have got some error on my restore.  i have attatached some logs. Can you help me about this issu.
Regards.
Pamela
