Using System Prompts
Answered Question
Feb 22nd, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
I am creating a script and would like to use some of the built in recordings under the Program Files\wfavvid\Prompts\system\G711_ULAW\en_US folder. I've tried just referencing them by name but it appears the system only looks to the User prompts repository. Does this mean I'll need to upload essentially copies of all the system prompts to the user prompts folder?
UCCX 7.0SR5
Correct Answer by William Bell about 7 years 5 months ago
When playing system prompts you would use the convention: SP[promptname.wav]  versus P[promptname.wav] that you use when playing a user prompt.
HTH.
Bill
Overall Rating: 5 (3 ratings)
Correct Answer
William Bell Mon, 02/22/2010 - 19:09
  • Purple, 4500 points or more
HTH.
Bill
Related Content
