LMS 2.6 with IPM 2.6 integration ACS 4.1, problem with IPM
Answered Question
Feb 23rd, 2010
Recently I integrated ACS 4.1 with LMS 2.6 follow this document:
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps2425/prod_white_paper0900aecd80613f62.html
The integration was a partial success, because after the integration I cannot run IPM client and Reports. Just I don't have the icon to run this features.
Some of you know why is happen, and if there is a solution?
In accord with the document above, I check the integration and was everything how this doc says. But IPM give me this problem.
Thank you really much.
Best Regards Antonello.
Correct Answer by Joe Clarke about 7 years 4 months ago
Do you see options for IPM in ACS under Shared Profile Components?
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Tue, 02/23/2010 - 18:27
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
antonello.moneta Wed, 02/24/2010 - 02:59
Thank you a lot Joe.
I wrongly thought that System Administrator has totally access.
Thank you really much, I rate you post.
Related Content
