Unable to connect cisco 2950 using telnet
Feb 23rd, 2010
hi,
i have two switches (cisco 2950)  i am going to configure the swithc configuration using tlenet unfortunately i given Vlan IP same for both and copied to "running config" but it was came with some errors. After some time i was unable to connect to both swithes using Tlenet. iy gives an eror as "unablle to open port no 23".
please can anybody tell me how i can go back to old configuration. (still the switch was not rebooted)
thnks in advance
Ganesh Hariharan Tue, 02/23/2010 - 04:14
hi,
thnks in advance
Check out the below link for recovering the password and configuration in cisco 2950 switches hopw that help
http://www.cisco.com/en/US/products/hw/switches/ps628/products_password_recovery09186a0080094184.shtml
If helpful do rate the post
Ganesh.H
