Ganesh Hariharan Tue, 02/23/2010 - 03:13
Hii,
Can anybody tell me how to use the archive command in to save routers and switch configuration in tftp server in a cretin time (daily or weekly  ...)
Check out the link below for kron policy configuration for scehdular backup on cisco devices hope that help
http://www.configureterminal.com/free/kron.html
If helpful do rate the post
Ganesh.H
Sybren.Apiecionek_2 Tue, 02/23/2010 - 05:03
amarmn1975
for weekly backup, your config should be:
ip tftp source-interface "fill_in_interface"
The archiving commands are:
archive
log config
  logging enable
  logging size 200
(<= This is the number of "comands issued by user X" that is saved in memory (if you use AAA, you can trace who changed what))
path tftp://IP_address/filename.txt
write-memory
(<= The config is saved to the tftp server if you perform a "write memory" or a "copy run start")
time-period 10800
(<= 10800 saves your config weekly, this is good enough if your network doesn't change daily).
but I prefer to use FTP as you can protect it with a username/password, if you use FTP it will look like:
ip ftp source-interface "fill_in_interface"
ip ftp username "username"
ip ftp password "password"
service password-encryption
archive
  log config
   logging enable
   logging size 200
(<= This is the number of "last comands issued by user X" is saved in memory (if you use AAA, you can trace who changed what))
  path ftp://IP_address/filename.txt
  write-memory
(<= The config is saved to the tftp server if you use a "write memory" or a "copy run start")
  time-period 10800
Sybren.Apiecionek_2 Tue, 02/23/2010 - 05:08
Milan
as you can see: I prefer to use time-priod & write-memory both in my config.
In case your collegue "forgets" to save the config, it is at least saved weekly :-)
Grt
S
milan.kulik Tue, 02/23/2010 - 05:49
yes, I understand.
But then you've got many config copies with no change in fact.
Each solution has pros and cons :-)
BR,
Milan
