masive snmp community change
Feb 23rd, 2010
if I need to change snmp community on regular basis on 400 devices, I guess I can usee cisco works and net config for this, but, then I need to manually change SNMP parameters on 400 devices in devices database. Can cisco works do it automatically during netconfig?
br
Joe Clarke Wed, 02/24/2010 - 18:07
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
If you use the SNMP Community template in Netconfig, Netconfig will handle updating DCR for you.  Just select "Replace" as the action type in the template.
