Question to RME4.0.4 LMS 2.5
Feb 23rd, 2010
i have a problem with the RME Archive Management. In the Archive Management is the Search Archive and her is my question. In the Search Archive it have Version ==> Latest and when i search the devices then the other version of the device ar also in my search. Why? I would like only search in the latest version of my configfiles.
Joe Clarke Wed, 02/24/2010 - 18:13
LMS 2.5.1 is close to being end of support (June of this year).  I highly suggest you upgrade to LMS 2.6 which can be freely downloaded from at .  I tested with RME 4.0.6, and I cannot reproduce the behavior you are seeing.  If I check the Latest radio button, I only see one configuration per device which matches a given search string.
