Using 3rd party SIP phones with UC500
Answered Question
Feb 23rd, 2010
A customer who has a complete setup of Snom SIP phones and some sort of hosted telephony service now want's to switch to an UC500 solution. Is there a way to reuse the current Snom phones with a UC500? If it's possible what sorts of drawback would there be instead of using Cisco phones?
Thanks!
Correct Answer by Steven DiStefano about 7 years 4 months ago
Its not going to be supported and interoperability with Cisco SCCP phones is not going to be predictable.  I dont recommend it.  I would guess you would be upside down on costs after the first week of trying to deploy it.  rather just buy the low cost Cisco SPA500 phones which operate in a tokenized SCCP protocol on UC500 called SPCP.  There is also some investment protection here, since if they want to go the hosted SP route, these phones also operate SIP.
Steve
Correct Answer by Steven Smith about 7 years 4 months ago
This is possible to do.  You can look on cisco.com and find guides that use SIP phones.
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_example09186a00808f33eb.shtml
The big problem is support.  When using 3rd Party SIP phones, support will be difficult to find.
Overall Rating: 5 (2 ratings)
Correct Answer
Steven DiStefano Tue, 02/23/2010 - 13:11
  • Blue, 1500 points or more
Steve
m.junghage Fri, 02/26/2010 - 02:55
Steve: Thank you for your response, I realize the issues that may occur when using non supported vendors. If it was just deskphones that would need replacement it would'nt be that big of a deal, but the half of the phones are IP-Dect phones with plenty of repeaters placed all over. Replacing them with Cisco's equivalent would be costly. What kind of functions would one miss if using 3rd party phones?
Steven: Thanks for the docs, looks interesting.
Steven DiStefano Fri, 02/26/2010 - 10:14
Having never connected them, I couldnt tell you.  Sorry.
