Can c3660,3640.3725,3745 support vacl
Feb 23rd, 2010
Hello Guys
i am practising for ccnp,ccvp and ccsp and i am using dynampis but some command does dont supported when it comes to make the mantioned router to support as a switch.
can any one help me out on this? or any IOS between those that can support configuration on vlan at global command and vtp global command and vacl?
or a way out to this, if is by buying those switches how much will cost me, so i can know if i can continue with this or stop, as you know third wolrd life. Dynampis is our only hope
waiting for your reply?
Lei Tian Tue, 02/23/2010 - 08:31
  • Cisco Employee,
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Hi Abdallah,
Dynamips is a great tool to simulate IOS software based router. Unfortunately, in switch a lot of features are done in hardware; include the vacl; so Dynamips is not able to simulate those hardware based features.
Besides buy old equipment on ebay, you can also rent some real devices to play on it. Just search on goolge for rent cisco, you should be able to find plenty of them.
HTH,
Lei Tian
Babuu_mpole Wed, 02/24/2010 - 01:59
hello
Is Ebay a trusted site? secondly they mostly send only inside USA or Canada and Europe, what about africa?
regards
babuu
Lei Tian Wed, 02/24/2010 - 05:29
  • Cisco Employee,
There always risk associate, you have to check the seller's record.
Not sure about that.
