Issue with UC500
Answered Question
Feb 23rd, 2010
  • Silver, 250 points or more
I try to configure Local speed dial on UC500
I found that i was able to input on uc only 32 directorys in an xml file
Does any one know how can i increase the directorys? when i put 33 and more i recieve on a phone xml error
Here is the config example
<CiscoIPPhoneDirectory>
<Title>Local Speed Dial</Title>
<Prompt>Record 1 to 1 of 1 </Prompt>
<DirectoryEntry>
  <Name>Andros</Name>
  <Telephone>9xxxxxxxx</Telephone>
</DirectoryEntry>
</CiscoIPPhoneDirectory>
Correct Answer by Paolo Bevilacqua about 7 years 1 month ago
The limitation is documented, if you want more you have to use different types of speed dials.
Overall Rating: 5 (2 ratings)
chrysostomos1980 Tue, 02/23/2010 - 07:14
thank you for the reply
could you pls be more specific ?
Can you give an example ?
Thank you and regards
Correct Answer
Paolo Bevilacqua Tue, 02/23/2010 - 06:26
  • Hall of Fame,
    Founding Member
