IP Phone Softkey while ringing
Feb 23rd, 2010
Hi, just finish the implementation of UCMBE. The customer decided not to invest in Attendant Console Software.
So we programmed a 7962 with two 7915. Everything is fine, but when she has a call in a transfer mode (not completed) and a call comes in, all her softkeys disappear and only Answer softkey does appear.
I verified in the softkey layout configuration for her phone and I found out that there is no possibility to have the keys to continue the transfer
before answering that call.
So she as to answer the second call (this put the first caller on hold...cancelling what was started before the second call.) put it on hold or transfer the call and then resume the first call taht was in mid transfer...very annoying.
Is ther something we can try or the answer is attendant console. ?
François
Overall Rating: 5 (1 ratings)
Rob Huffman Tue, 02/23/2010 - 06:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Francois,
Try changing the System setting Auto-Call Select. With this Enabled the Display Focus (and Softkeys) always switch to the new incoming call. So if disabled the focus and Softkeys will stay on Call #1.
Also available on an individual phone via this setting;
Device>Phone>Phone Configuration>Product Specific Configuration>Auto Call Select>Disabled
Hope this helps!
Rob
FRANCOIS LEROUX Tue, 02/23/2010 - 07:34
Thanks , It does work....I did not find the system setting, but I did apply
the Phone settings, since it is the one we are concern about.
Thanks Again
François.
2010/2/23 rob.huffman
fleroux,
A new message was posted in the Discussion thread "IP Phone Softkey while
ringing":
https://supportforums.cisco.com/message/3023786#3023786
Author : rob.huffman
Profile : https://supportforums.cisco.com/people/rob.huffman
Message:
