Ports connected to End Users.
Feb 23rd, 2010
Do you know any monitoring tool where I can see how many ports is using any Cisco switch and that I can export it to any software like Excel ?.
Thank you, best regards.
Joe Clarke Wed, 02/24/2010 - 18:37
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, this is exactly the purpose of CiscoWorks Campus Manager's User Tracking component.  User Tracking will find end users connected to switch ports by their MAC addresses.  It will then correlate ARP table entries from managed routers to populate IP information.  Finally, using a small piece of software running on Windows end hosts, UT can show the username of the user connected to the port.
A 90-day eval of CiscoWorks LAN Management Solution can be downloaded from http://www.cisco.com/go/lms/ .
