UCCX 5.02 SR2 ok with CUCM 6.1.5 ?
Answered Question
Feb 23rd, 2010
  • Silver, 250 points or more
I have to upgrade Call Manager from 6.1.4 to 6.1.5 to address an issue we are facing on the Call Manager side, is UCCX 5.02 SR2 ok with 6.1.5?
I checked the cRS matrix and 6.1.5 is not listed yet.
Thanks, Erick
Correct Answer by Ryan LaFountain about 7 years 1 month ago
Yes, UCCX 5.0(2)SR2 has been qualified with CUCM 6.1.5. I will work on getting the documentation updated in the background. Thanks for bringing this to our attention.
Overall Rating: 5 (1 ratings)
Correct Answer
Ryan LaFountain Mon, 03/08/2010 - 14:41
  • Cisco Employee,
Erick Bergquist Mon, 03/08/2010 - 15:53
Thanks, I had applied the 6.1.5 update 1-2 weeks ago and haven't had any problems. Figured it was fine. I did a JTAPI sync after applying 6.1.5 and it found no changes also.
