Change in behavior of ssh session after IOS upgrade
Answered Question
Feb 23rd, 2010
I upgraded a series of 3560s and 4506s to version 12.2(53)SE and 12.2(53)SG1, respectively.  Before the upgrade, I would login to the switches using an SSH client.  I'd enter a user id and password for the initial connection and then if I wanted to get into enable mode, I had to enter a separate password.  Now, after the upgrade, on the 3560s, I am automatically placed into enable mode after entering the initial userid/password sequence.  There's no need to enter a separate enable password.  On the 4506s, the functionality is the same as before the upgrade.  Any ideas on what happened and how I might be able to get the 3560s back to the original behavior?
Correct Answer by Ganesh Hariharan about 6 years 12 months ago
It can be problem with aaa configuration in your switches for enable mode authentication just check out the below sample configuration which will go for enable level password authentication also with TACAS server configured for authetication.
aaa new-model
aaa authentication login default group tacacs+ line
aaa authentication enable default group tacacs+ enable
Hope to Help !!
If helpful do rate the post
Ganesh.H
Correct Answer by Giuseppe Larosa about 7 years 8 hours ago
Hello Sdavids5670,
without seeing your configuration and may be the output of appropriate debug commands is difficult to say what has changed.
It should be more related to AAA commands rather then the use of SSH instead of telnet.
skip username and passwords, change your public ip addresses if any on devices and post the configuration.
probably a default AAA command was changed and it is causing this behavior.
Hope to help
Giuseppe
Overall Rating: 5 (2 ratings)
Correct Answer
Giuseppe Larosa Mon, 03/01/2010 - 13:41
Hello Sdavids5670,
Hope to help
Giuseppe
Correct Answer
Ganesh Hariharan Mon, 03/01/2010 - 22:45
aaa new-model
Hope to Help !!
Ganesh.H
sdavids5670 Wed, 03/03/2010 - 07:06
Thanks for the help.  There were two approaches to returning the behavior back to what it was before the upgrade.  I either a) needed to add 'aaa new-model' to the configuration or b) I needed to remove the 'password' command from the 'line vty' section.  Either one worked.
