CM 7 Ringtones
Answered Question
Feb 23rd, 2010
Looking to add ringtones to a CM7 cluster, so they are available to users via settings/user preferences /rings.  Currently, I only have 2
thanks
Correct Answer by Tommer Catlin about 7 years 2 days ago
You want to add it for all phones or to just your phone?  If you want, you can use the widget Phone Designer to upload your own to the phone.
http://www.cisco.com/en/US/products/ps9829/index.html
basically anything you want with this.
IF you search through the forums, you will find how to upload ring tones for all phones to use.  Its a process for the file to be recorded a certain way, XML file updated so its listed correctly, etc
Overall Rating: 5 (1 ratings)
Correct Answer
Tommer Catlin Tue, 02/23/2010 - 09:23
