Upgrading IOS on 3548 XL switch
Answered Question
Feb 23rd, 2010
Hi all,
I need to upgrde ios on this switch.
i have installed new IOS  version on my laptop.
Now in order to remove old ios and upgrade to new ios i can run the command
copy tftp to flash?
please let me know
thanks
mahesh
Correct Answer by Jon Marshall about 7 years 1 month ago
mahesh18 wrote:
Hi Francisco,
Thanks for reply.
So from switch i can run the copy tftp command then when that it is done go to config t
and type the command exactly as you mentioned and do reload then switch will have new ios?
let me know
many thanks
Mahesh
Yes, copy the image to flash and then
switch(config)# boot system flash flash:
Jon
Correct Answer by Francisco Del Cura about 7 years 1 month ago
If you have enough flash for both don't delete the old version.
In orde to copy the IOS into the switch type:
#copy tftp://IP_laptop/file.bin flash:
Once copied configure the switch loads with the new IOS when it boots:
#conf t
#boot system file.bin
#reload
Overall Rating: 5 (2 ratings)
Correct Answer
Francisco Del Cura Tue, 02/23/2010 - 09:48
#conf t
#reload
mahesh18 Tue, 02/23/2010 - 11:18
Hi Francisco,
Thanks for reply.
let me know
many thanks
Correct Answer
Jon Marshall Tue, 02/23/2010 - 11:24
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
mahesh18 wrote:
Hi Francisco,
Thanks for reply.
let me know
many thanks
Mahesh
Jon
