Calling router Initial a ISDN call ,but receive "SETUP" message
Feb 23rd, 2010
Config:
controller E1 0/3/0
framing NO-CRC4
pri-group timeslots 1-31
interface Serial0/3/0:15
no ip address
encapsulation hdlc
no logging event link-status
no snmp trap link-status
isdn switch-type primary-net5
isdn overlap-receiving
isdn protocol-emulate network
isdn incoming-voice voice
isdn send-alerting
voice-port 0/3/0:15
dial-peer voice 514 pots
destination-pattern 514.....
direct-inward-dial
port 0/3/0:15
forward-digits 8
The error message:
*Feb 24 01:35:34.041: ISDN Se0/3/0:15 Q931: Sending SETUP  callref = 0x01D1 callID = 0x8156 switch = primary-net5 interface = Network
*Feb 24 01:35:34.041: ISDN Se0/3/0:15 Q931: TX -> SETUP pd = 8  callref = 0x01D1
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Called Party Number i = 0x80, '51466000'
                Plan:Unknown, Type:Unknown
*Feb 24 01:35:34.065: ISDN Se0/3/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x81D1
*Feb 24 01:35:34.069: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8  callref = 0x1D63
                Standard = CCITT
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
Paolo Bevilacqua Tue, 02/23/2010 - 11:42
You are connrcting to a PBX, such PBX is configured so that calls for 51466000 go out to router again.
So this is not a problerm with the router, and you have to fix the PBX.
