Cisco 800 series NAT - Port Fordwarding trouble
Feb 23rd, 2010
Mostrar forma romanizada
Dear,
I am having some problems with my cisco 800 series  router when i try to make  a Port Fordwarding.
I wonder if there are any special access list to  be programmed to enforce this.
Thank you very much for your attention.
paolo bevilacqua Tue, 02/23/2010 - 11:27
  • Hall of Fame,
    Founding Member
You need to specify what command exactly you entered.
patelero1 Tue, 02/23/2010 - 11:37
I'm traying with:
access-list 1 permit 10.0.0.0 (My IP Range)
ip nat inside source static tcp 10.0.0.100 3200 interface Dialer1 3200
paolo bevilacqua Tue, 02/23/2010 - 11:48
  • Hall of Fame,
    Founding Member
That is fine, make sure you have ip nat ouside under Dialer1, and Ip NAT inside under internal If.ce
patelero1 Tue, 02/23/2010 - 13:02
Sorry,
I have IP nat inside but on my vlan interface to connect my ISP, what do yo mean with internal lf.ce?
paolo bevilacqua Tue, 02/23/2010 - 14:09
  • Hall of Fame,
    Founding Member
Ip nat inside on inside interface, outside on the outside.
Kind of logic if you think about.
