02-23-2010 11:01 AM - edited 02-21-2020 03:53 AM
I know in the ASA5520 we use, i can created multiple syslog servers to send syslogs to. However, I am
wondering, is there a way to segment the data? IE - We have a "generic" syslog server that gets all the syslog data (ncluding Informational), but I would like to create a second syslog entry on the ASA (pointing to a different IP address) and have it ONLY send specific message types.
Basically, I am wanting to have the messages related to the Botnet filtering send to a differnt syslog server.
Is this possible?
02-23-2010 02:23 PM
Unfortunately, that cannot be configured.
The syslogs sent will be the same to all syslog servers.
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/monitor.html
PK
03-14-2010 03:46 PM
Here is a thought may be this might work for you.
Refer this link for botnet:
https://supportforums.cisco.com/docs/DOC-8782
botnet syslogs
338001 - 338004
338101 - 338104
338201 - 338204
338301 - 338310
Refer this link for logging commands:http://www.cisco.com/en/US/docs/security/asa/asa82/command/reference/l2.html#wp1772272
1. configure a logging list and send it to buffer and wrap that to ftp server
hostname(config)# logging list my-list 338001 - 338004hostname(config)# logging list my-list 338101 - 338104
hostname(config)# logging list my-list 338201 - 338204
hostname(config)# logging list my-list 338301 - 33831
hostname(config)# logging buffered my-listhostname(config)# logging ftp-server 10.10.10.1 /syslogs userid passwordhostname(config)# logging ftp-bufferwrap
2 Then you can send other syslogs to another syslog server
hostname(config)# logging trap 3
hostname(config)# logging host inside 10.10.10.2
-KS
11-21-2013 09:54 AM
I was wondering also if there is a way to send only specific log messages (defined by the logging list) to one server while still sending the rest to another syslog server?
