ASA 5510 7.0 Need to tunnel to two different sites with same LAN subnet
Feb 23rd, 2010
We have an ASA5510 that
connects to the internet with a static IP address
and connects to our LAN with a static  IP  address.
We allow client connections on tunnel group First   type ipsec-ra
group-policy First internal
ip local pool First 192.168.120.2-192.168.120.200
nat (inside) 0 access-list inside_nat0_inbound
nat(inside) 0 0.0.0.0 0.0.0.0
We also have several peer-to-peer tunnels
tunnel-group nnn.nnn.nnn.nnn type ipsec-121
and these are working.
Now I have two other remote offices who have both built their LANs  on subnet
192.168.1.0/24.  I need to build peer-to-peer tunnels to both of these locations.
Is there a way to nat the addresses of the two locations individually as they enter the ASA5510
from the internet
Thanks for your help,  Pam
busterswt Tue, 02/23/2010 - 20:09
  • Bronze, 100 points or more
Hi Pam,
I don't know of any way to NAT the traffic as it enters the 5510, but if the remote branches are ASA's or PIX's then you can implement Policy NAT on those devices to achieve what you're looking for. The documentation for the PIX can be found here, under 'Configuring Policy NAT'. The ASA would be similar, if not the same...
http://www.cisco.com/en/US/docs/security/pix/pix63/configuration/guide/bafwcfg.html#wp1113601
It is possible, through static NAT trickery, to do what you want on the 5510 *so long as* there are no overlapping IPs between the overlapping subnets. I wouldn't recommend this though as it can likely get confusing pretty quickly. I would look into the Policy NAT if at all possible.
James
