Router problem with L2TPv3 over IPSec over internet: 100% CPU utilization cause reassembly of packets.
ROBERTO TACCON
Level 4
Level 4
*** Here's the enviroment:
2 routers (Catalyst 2801 and 2821) each connected on "big internet".
Between the routers there are:
- VPN IPSec VPN
- inside the IPSec VPN a L2TPv3 tunnel.
*** Here's the problem:
When i test the connection I get the result i expect as long as the packet size is smaller then 1400.
Once the packet size is 1500 the cpu of one of the two routers gets to 100% and the throughput lowers to +/-1Mb/s.
Is there any option to avoid the problem with IPv4 traffic (TCP and UDP) ?
Can you check the configuration (in particular for mtu and mss options) ?
Is there any configuration option/feaure to avoid 100% CPU utilization ?
Following the configuration:
Router 1:
version 12.4
service timestamps log datetime localtime show-timezone
hostname router-1
boot-start-marker
boot system flash:c2801-adventerprisek9-mz.124-25c.bin
boot-end-marker
logging buffered 64000 debugging
no logging console
no aaa new-model
ip cef
ip domain name cisco.com
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
voice-card 0
username xxxxxxxxxxxxxx privilege 15 xxxxxxxxxxxx
ip ssh version 1
pseudowire-class vlan-xconnect
encapsulation l2tpv3
protocol none
ip local interface Loopback1
ip tos reflect
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 2
encr aes 256
group 5
crypto isakmp key cisco address 1.20.1.157
crypto ipsec transform-set ESP-AES256-SHA esp-aes 256 esp-sha-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
description *** Tunnel to 1.20.1.157
set peer 1.20.1.157
set transform-set ESP-AES256-SHA
match address 100
interface Loopback1
description *** L2TPv3 Tunnel Source
ip address 172.20.20.251 255.255.255.255
ip mtu 1420
ip tcp adjust-mss 1300
interface Null0
no ip unreachables
interface FastEthernet0/0
description *** LAN INTERNAL
no ip address
duplex auto
speed auto
no cdp enable
xconnect 172.20.20.250 1 encapsulation l2tpv3 manual pw-class vlan-xconnect
  l2tp id 1002 2001
  l2tp cookie local 4 102
  l2tp cookie remote 4 201
interface FastEthernet0/1
description *** INTERNET
ip address 2.1.4.7 255.255.255.224
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 2.1.4.6
no ip http server
no ip http secure-server
access-list 100 remark IPSec phase 2 Rule
access-list 100 permit ip host 172.20.20.251 host 172.20.20.250
access-list 100 deny   ip any any log
control-plane
line con 0
login local
line aux 0
line vty 0 5
exec-timeout 5 0
login local
scheduler allocate 20000 1000
Router 2:
version 12.4
service timestamps debug datetime localtime show-timezone
service password-encryption
hostname router-2
boot-start-marker
boot system flash:c2800nm-adventerprisek9-mz.124-25c.bin
boot-end-marker
no logging console
aaa new-model
aaa authentication login default local
aaa authentication login clientauth local
aaa authorization exec default local
aaa session-id common
clock timezone Rome 1
clock summer-time Rome recurring last Sun Mar 2:00 last Sun Oct 3:00
no ip source-route
ip cef
ip multicast-routing
login block-for 60 attempts 3 within 20
login on-failure log
login on-success log
voice-card 0
no dspfarm
username xxxxxxxxxxx privilege 15 password xxxxxxxxxxxxxxxxxxxxxxxx
archive
log config
  hidekeys
protocol none
ip tos reflect
encr 3des
group 2
encr aes 256
group 5
crypto isakmp key cisco address 2.1.4.7
crypto isakmp keepalive 120 5
description *** Tunnel to 2.1.4.7
set peer 2.1.4.7
match address 100
interface Loopback0
no ip address
load-interval 30
interface Loopback1
ip address 172.20.20.250 255.255.255.255
ip mtu 1420
interface Null0
no ip unreachables
interface GigabitEthernet0/0
description ** To Internet **
ip address 1.20.1.157 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip virtual-reassembly
load-interval 30
interface GigabitEthernet0/1
description ** To internal networks **
no ip address
load-interval 30
duplex auto
speed auto
no cdp enable
xconnect 172.20.20.251 1 encapsulation l2tpv3 manual pw-class vlan-xconnect
  l2tp id 2001 1002
  l2tp cookie local 4 201
  l2tp cookie remote 4 102
ip route 0.0.0.0 0.0.0.0 1.20.1.156 name default
ip flow-top-talkers
top 10
sort-by bytes
cache-timeout 1000
no ip http server
access-list 100 permit ip host 172.20.20.250 host 172.20.20.251
control-plane
line con 0
line aux 0
line vty 0 4
exec-timeout 5 0
transport input telnet ssh
escape-character 3
7 Replies 7
paolo bevilacqua
Can't you configure your systems so to avoid bridging in first place?
Edison Ortiz
Fragmentation is to be avoided in PW topologies. What you are seeing is quite normal.
Please refer to this article http://tools.ietf.org/html/draft-ietf-pwe3-fragmentation-10
1) As my transport is the "big internet" the MTU path between the 2 routers can be controlled
2) As the traffic inside the tunnel (the private traffic) is IP over ethernet (1500 byte) and the header of IPSEC and L2TPv3 add header need to fragment as the traffic between servers is UDP and TCP with or without DF ...
are there any L2TPv3 and IPSec Header compression method ?
which L2TPv3 configuration use the minimum header ?
which IPSec encryption protocol configuration use the minimum header ?
ROBERTO TACCON
Level 4
Level 4
The customer have 2 small DataCenter connected by different ISP: on the 1st old DC  there're 50 server with private IP 10.0.0.0/24 and public IP x.x.x.x/24 (the public ip address are PA assigned), on the 2nd new DC there're nothing (now).
The customer need to connect the 2 DC in the fastest way and "bring" the servers on the old and on the new DC.
As the only connection between the 2 DC are internet I try to use a L2L VPN bridging traffic...
Are there any other fast solution using internet: (L2TPv3 over IPsec) (using a simple VPN IPSEC need to do NAT) ?
Thanks for all !
Roberto Taccon
You have of of the few cases in which bridging would be really needed. Unfortunately, it never works well over the internet.
Try bridging over GRE (unsupported, may work)
Thanks for the solution with GRE ...
Please can you check the following sample configuration with internet IP as GRE tunnel source and destination:
it's possible to use "no ip address" on the gre tunnel ?
how i can resolve the extra GRE header encapsulation with the MTU ?
#router-1
bridge irb
bridge 1 protocol ieee
interface Tunnel1
description GRE tunnel to router-2
no ip address
tunnel source FastEthernet0/1
tunnel destination 8.8.8.9
bridge-group 1
bridge-group 1 spanning-disabled
description Link to lan 10.0.0.0/24
no ip address
duplex auto
speed auto
bridge-group 1
description *** Link to internet
ip address 1.2.3.5 255.255.255.252
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 1.2.3.6
#router-2
bridge irb
interface Tunnel1
description GRE tunnel to router-1
no ip address
tunnel destination 1.2.3.5
bridge-group 1
no ip address
duplex auto
speed auto
bridge-group 1
ip address 8.8.8.9 255.255.255.252
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 8.8.8.10
I think you need an additionar pair of routers, with ip routing disabled, for bridging over GRE.
You cannot do anything about MTU. just hope applications will still work. They may not.
