Frame Relay configuration help
I think my config is correct, but I can't even ping the local IP address on each spoke router, on a hub and spoke network. I have a 2610 as the switch, and all routes are active:
RA#sh frame-relay route
Input Intf Input Dlci Output Intf Output Dlci Status
Serial1/0 333 Serial1/1 111 active
Serial1/0 444 Serial1/2 222 active
Serial1/1 111 Serial1/0 333 active
Serial1/2 222 Serial1/0 444 active
Sorry, no chart, but RA is the switch, and the spokes are
RC 10.10.1.1 DLCI 111
RD 10.10.1.3 DLCI 333
DLCI 444
RE 10.10.1.5 DLCI 222
Here is the bad news from the spokes:
RC#sh frame map
Serial0 (up): ip 10.10.1.3 dlci 111(0x6F,0x18F0), static,
              broadcast,
              CISCO, status deleted
RE#sh frame map
Serial0 (up): ip 10.10.1.1 dlci 222(0xDE,0x34E0), static,
              broadcast,
              CISCO, status defined, active
RD#sh frame map
Serial0 (up): ip 10.10.1.1 dlci 333(0x14D,0x50D0), static,
              broadcast,
Serial0 (up): ip 10.10.1.5 dlci 444(0x1BC,0x6CC0), static,
              broadcast,
Paolo Bevilacqua Tue, 02/23/2010 - 14:46
Take no offense, but if it was correct, you would be able to ping and more.
Now, if you don't post your config, how others can help you ?
Please take a look at my config – everything is active, but can’t ping
Router A is the frame switch using 3 serial interfaces
RD 10.10.1.3   DLCI 333  in to s1/0 on switch, frame routes to RC out s1/1
RD 10.10.1.3   DLCI 444  in to s1/0 on switch, frame routes to RE out s1/2
RC 10.10.1.1   DLCI 111  in so s1/1 on switch, frame routes to RD out s1/0
RE  10.10.1.5  DLCI 222  in to s1/2 on switch,  frame routes to RC out s1/0
ROUTER A Frame Relay Switch sh running-config
interface Serial1/0
no ip address
encapsulation frame-relay
logging event subif-link-status
logging event dlci-status-change
clock rate 56000
no frame-relay inverse-arp
frame-relay intf-type dce
frame-relay route 333 interface Serial1/1 111
frame-relay route 444 interface Serial1/2 222
interface Serial1/1
no ip address
clock rate 56000
frame-relay route 111 interface Serial1/0 333
interface Serial1/2
no ip address
clock rate 56000
frame-relay route 222 interface Serial1/1 111
RA#sh frame route
Serial1/2       222             Serial1/1       111             active
ROUTER C (12.3 IOS)
RC#sh frame map
              broadcast,
interface Serial0
ip address 10.10.1.3 255.255.255.0
no fair-queue
frame-relay map ip 10.10.1.3 111 broadcast CISCO
frame-relay interface-dlci 111
ip classless
ROUTER D  (11.1 IOS)
RD#sh frame map
              broadcast,
              broadcast,
RD#Show running-config
interface Serial0
frame-relay interface-dlci 333
frame-relay interface-dlci 444
frame-relay map ip 10.10.1.1 333 broadcast CISCO
frame-relay map ip 10.10.1.5 444 broadcast CISCO
ip classless
ROUTER E (11.1 IOS)
RE#sh frame map
Serial0 (up): ip 10.10.1.3 dlci 222(0xDE,0x34E0), static,
              broadcast,
RE#sh run
interface Serial0
ip address 10.10.1.5 255.255.255.0
frame-relay interface-dlci 222
frame-relay map ip 10.10.1.3 222 broadcast CISCO
ip classless
Message was edited by: Steve Cobb
I created subinterfaces, multipoint, and now it works no problem. I didn't know that subinterfaces were required in frame relay, but that is the only way that I could see to enable that command is on a subinterface. I will assume that subinterfaces are required for frame relay, unless there is a way to specify multipoint on the physical interface that I am not aware of.
Anyone?
