Lightweight to Autonomous
Answered Question
Feb 23rd, 2010
Can someone provide the correct way to 'downgrade' an air-lap1242ag to an autonomous AP?
Correct Answer by jorge.novo about 7 years 4 months ago
Hi Robert,
1st     Configure your PC with one of this IP address 10.0.0.2 ==> 10.0.0.30 and use direct ethernet connection with your AP
2nd     Download the IOS file from Cisco
3rd     Rename the file with one of this name:
c1200-k9w7-tar.default for a 1200  series access point
c1130-k9w7-tar.default for an 1130 series  access point
c1140-k9w7-tar.default for an 1140 series access point
c1240-k9w7-tar.default for a 1240 series  access point
c1250-k9w7-tar.default for a 1250 series  access point.
4th     Use you favourite tftp server program and put the renamed file on the correct folder.
5th     Unplug the power on the AP and press the MODE button, hold...
6th     Plug the power and wait about 20-30 sec with the MODE button pressed, release the button
             (You could see the in the tftp Server log your AP going and also in the terminal)
That's all, wait for the AP finish the downloading process and reboot
I hope this helps
Overall Rating: 0 (2 ratings)
Leo Laohoo Tue, 02/23/2010 - 15:19
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hi Robert,
Do you have a WLC or not?
robert.horrigan Tue, 02/23/2010 - 15:20
Not for this project.  I need to use this AP as a complete standalone solution.
Leo Laohoo Tue, 02/23/2010 - 16:06
  • Hall of Fame,
    2017 LAN, Wireless
Correct Answer
jorge.novo Wed, 02/24/2010 - 11:53
Hi Robert,
I hope this helps
genrique64 Thu, 02/16/2012 - 05:57
hi, i do it everiting but my ap after reboot only stay "
File "flash:/c1200-k9w7-mx.122-15.JA/c1200-k9w7-mx.122-15.JA" uncompressed and installed, entry point: 0x3000
executing...
what can i do
tuhpatel Thu, 02/16/2012 - 08:32
  • Cisco Employee,
Alternate very useful method :
Console into the AP :
1.Install an external TFTP tool such as tftpd32 tool from http://tftpd32.jounin.net/
2. Make sure you set the IP address for the AP if not set.
3. Download the IOS image onto the tftp's root directory. Use www.cisco.com-->support-->download software-->wireless software--> AP .-> Select IOS software.
4. Connect the ethernet port on AP to your TFTP Server ( Laptop )
5. On AP, type
debug capwap console cli
debug capwap cli no-reload
archive download-sw /overwrite /force-reload tftp://192.168.5.12/c1140-k9w7-tar.124-25d.JA.tar
default password: Cisco
Vinay Sharma Wed, 02/22/2012 - 11:50
  • Gold, 750 points or more
Thanks Tuhin for sharing alternate method for conversion 5+
Vinay Sharma
Community Manager
Ditmar Tavares Wed, 04/18/2012 - 11:35
I have a 1242 and have followed the step you advised, but I'm not getting anywhere.
the dialog  box of copying file is showing up in my tftp21 but after couple seconds I got an error message.
- I can't console into the AP either.
any suggestion.
alaporte Fri, 04/27/2012 - 12:28
Just had the same problem with tftp32d.  Not sure what is up with it maybe a bug but I was able to get SolarWinds tftp to work.  I think you can get a free version off their site if you need it.
Andy
