can't bring the link between 4400 controller DS port and 2950 trunk port up
Feb 23rd, 2010
I'm trying to setup 4400 WLAN conroller and Aironet 1000, connected controller's DS port 1 to Catalyst 2950 fastethernet trunk port, but the link never comes up. What configuration I need to do on 4400 and 2950? Is this because 2950 is not supported with 4400?
lockdown2 Tue, 02/23/2010 - 17:01
I tried 2950 giga port also that connected to DS port 2, and disabled spanning-tree on 2950 trunk port. but the link never came up. I did not config RADIAS yet, only connect Aironet 1000's ethernet port to 2950, and 2950 uplinked to network, AP's ethenet is up. the first I need to bring up DS port then I will be able to ping AP from controller. Any one can help?
Leo Laohoo Tue, 02/23/2010 - 17:38
The link won't come up because you are connecting the 4400's 1Gb (only) to a 10/100 mb port.  The 4400's 1Gb will not support 10 or 100 mb.
lockdown2 Wed, 02/24/2010 - 10:35
Thanks Leolaohoo,
I have tried 2950 giga port also and it did no come up, is this because I use DS port 2? I can't use port1, because I could not pull out the SFP from port1. I do not see any setting difference in port 1 and 2, what config I need to do on port2? The management and ap-manager interfaces are configured with vlan 2, I do not think the vlan is the issue that causes the link down, because 2950 giga port is trunk. the vlan 2 configured on controller is tagged vlan (I think) , not native vlan, so the tag and untag should not be an issue here.
Thanks a lot.
jorge.novo Wed, 02/24/2010 - 11:38
Hi Jamie,
This is a Cisco AS4400 Wireless Lan Controller
And this is a configuration that is working in a Cisco AS5508  Wireless Lan Controller and Cisco Catalyst 3560G PoE
interface Port-channel10
description Conexion Etherchannel con Cisco 5508 Wireless Controller
switchport mode trunk
interface GigabitEthernet0/31
channel-group 10 mode on
interface GigabitEthernet0/32
Remember that the configuration is for a etherchannel trunk, nor LACP nor PaGP (both does not work) Only Etherchanel
If you only want a 1Gbps link delete the interfae Port-channel config and "channel-group mode on", more or less like this
You must disable the "LAG Mode on next reboot" in the Wireless Lan Controller => Controller => General and then reboot cos in the last conf you aren't use the LAG mode (Etherchanel)
I hope this helps
lockdown2 Wed, 02/24/2010 - 16:16
Thanks Jorge,
I follow your instruction to check my controller and it already has "LAG mode on next reboot" disabled (and it also "oprating in layer3 mode"), configuration on Catalyst 2950 giga port is trunk mode, single port w/o etherchannel, anything else you think may cause the link down? controller side or Catalyst side? vlan?
Many thanks
Leo Laohoo Wed, 02/24/2010 - 16:39
What is the exact model of your 2950?  What modules (SFP and/or GBIC) are you using between your WLC and your 2950?  What is the firmware you are running on the WLC?  Do you get any logs on the WLC saying something like "module inserted not supported" or something?
lockdown2 Wed, 02/24/2010 - 18:37
Hi Leolaohoo,
I really appreciate your prompt response.
I collected the controller's and Catalyst's sysinfo and controller's log and attache here.
The log has lots of failures that complain "failed to read configuration file" and list lots of cfg file names, there is one line complains distribution service interface, I do not understand the error, but I guess it is not related to the link down issue. It seems that the controller has many configuration issues.
George Stefanick Wed, 02/24/2010 - 19:50
Did you use native or tag on the switch interface ? Is the switch inteface light on green / amber? Can you do a show interface in the switch for that port and post ?
lockdown2 Thu, 02/25/2010 - 11:47
Hi George,
Thanks for your reply, here is my Catalyst 2950 running-config, switcfport and vlan info. I never saw 4400 controller's DS port talk with 2950 giga port, the LED indicators never blinked, I do not know what this means, does it means the physical connection not work, or the physical port not work? or may be because the two ports' configuration are not match?
I really appreciate your help.
Leo Laohoo Thu, 02/25/2010 - 23:52
You haven't mentioned about what firmware you are running and what SFP modules you are using.  The reason why I'm asking is because in there's a bug that will cause the WLC not to recognize some SFP.
lockdown2 Mon, 03/08/2010 - 17:57
I attached 7 files here, but I could not see them, can you see them? I failed to copy them into this text box, have to type some here:
Cisco Internetwork Operating System Software IOS (tm) C2950 Software (C2950-I6Q4L2-M), version 12.1(14)EA1a, RELEASE SOFTWARE (fc1)
Sytem image file is "flash:/c2950-i6q4l2-mz.121-14.EA1a.bin"
cisco WS-C2950G-24-EI (RC32300) processor (revision HO).
Which one is firmware version?
one of DS port is copper SFP and one is fiber. I could not pull out the copper SFP.
Leo Laohoo Mon, 03/08/2010 - 17:59
Hmmmm ... Maybe my question is confusing.  What is the firmware of the WLC?
lockdown2 Fri, 03/12/2010 - 18:56
4400 WLC has   software    version
                         product     version
                         RTOB        version
I don't known which one is firmware.
Kayle Miller Fri, 02/26/2010 - 08:12
Lockdown user,
     As several people have mentioned I as well have seen issues with various SFP's, even if they were supported I had issues if they didn't match. the other thing you haven't mention is whether your using copper or fiber SFP's. So definitely check the SFP's.
lockdown2 Mon, 03/08/2010 - 18:17
I found a way to pull out the copper SFP in DS port on 4400WLC and got the info:
LINKSYS  (Cisco logo is here)
Gigabit Ethernet 1000 Based-T
Minit-GBIC SFP Transceiver
1000M SFP   21 CFR(J) class 1
Related Content
