CSS11513 not sending Fin packet
Feb 23rd, 2010
We have a CSS laadbalancer connecting to a couple of ldap servers. The ldap look up takes longer than usual and there is pooling set up on the ldapserver. The issue is the css does not send a FIN ad as a result the session stays open on the ldap but is lost on the css. The question are there any timers we can set to send a FIN before the CSS tears the session down?
Gilles Dufour Wed, 02/24/2010 - 09:19
You can use the command 'flow-timeout-multiplier' under a content rule to increase the idle timeout.
Another option is the global command 'flow permanent port1 '
This will prevent the CSS to timeout connections automatically.
