monitor a remote span vlan and a local vlan on the same switch
Feb 23rd, 2010
Hello ,
I need to monitor a remote span vlan and a local vlan to the same local interface  on  a 6509  switch .
When i have used monitor session source command , i  could not
add them both .
I also could not do it with two monitor sessions (  one for remote span vlan and one for the other local vlan )
to the same destination interface .
How can I do it  ?
Best Regarads ,
Giuseppe Larosa Mon, 03/01/2010 - 13:02
  • Hall of Fame,
    Founding Member
Hello David,
this looks like a dead lock.
there is no way for you to setup two different sniffers?
Hope to help
Giuseppe
Ganesh Hariharan Tue, 03/02/2010 - 00:04
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hello ,
add them both .
How can I do it  ?
Best Regarads ,
Hi David,
Check out the below link for pre -requiste for spanin cisco 6500 series switches.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/configuration/guide/span.html#wp1032979
Hope that Help !!
Ganesh.H
Kevin Dorrell Tue, 03/02/2010 - 00:18
  • Green, 3000 points or more
You could try this, but I don't know whether it works.  I know the switch allows it, but I didn't have a look at the output to check it.
monitor session 1 source remote vlan 40
monitor session 1 destination interface F6/12
monitor session 2 source interface F6/11
monitor session 2 destination remote vlan 40
I reckon interface F6/12 should show the traffic on the RSPAN VLAN, plus interface F6/11.
Kevin Dorrell
Luxembourg
