Maximum distance for VSS and VSL
Feb 24th, 2010
Can someone tell me till how much distance can we have VSL,
I have 2 x 6509 serving as redundant switches and now i plan to upgrade to VSS, but both switch are 2KM away from each other.
Tabrez
fly Tue, 12/13/2011 - 17:17
i have same question , no one answer me.
i have seen vss all in same location utill now!
i am interesting to implement vss in different location , about 50 km to 80 km distance.  but i haven't seen any real experience.
balbaletabrez Sun, 04/29/2012 - 07:55
At a distance of 2 Kms it did work .....for you it should work with ZR.
Leo Laohoo Sun, 04/29/2012 - 15:38
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
I have a VSS pair and the distance is about 20 Km.  It works but I wouldn't recommend it.
fly Fri, 07/27/2012 - 23:29
Hi Leo
  Why you didn't recommend it?
  Thank you
Fly
Leo Laohoo Sat, 07/28/2012 - 00:00
  • Hall of Fame,
    2017 LAN, Wireless
If, for example, the VSS will go into "split-brain" then you don't want to drive 20 Kms away just to give the 2nd unit a kick-in-the-guts.
Particularly, when the outage is severely disrupting services.
If I wanted a VSS pair, I want it to be no more than 50 metres away.
