spa3102 help
Feb 24th, 2010
hello, I auito, I bought an SPA3102 and I want to configure it as follows:
include an internal analog of my corporate PBX SPA3102 in turning the line into my voip
I wish I could configure my home 3cxphone or similar in my PC so that you can use my internal phone remotely
I need to know how to configure parameters such as 3102 and especially putting then in 3cxphone or equivalent to make it work
if someone helps me I will be 'very grateful unfortunately not very good, thank you in advance who declares also the only time to read this message
Alberto Montilla Wed, 02/24/2010 - 05:50
Dear Sir;
I suggest you read the ATA Admin Guide located in the Another possibility is that you call our Small Business Support Center, they should be able to attend you in your native language. Numbers for the SBSC are located in the main page of this community (under support link).
