Outbound Dialer & CRM
Answered Question
Feb 24th, 2010
In outbound dialer can we use DB/Database or CRM  to import contacts for dialing instead of uploading numbers in import file ?
Correct Answer by arifsultanal about 6 years 11 months ago
One thing you can do from your CRM Side that is , your CRM will through file at your FTP site( from where outbound dialer import files  ). You dont need to upload numbers manually.
you have to make  a schedule at CRM and make some programming to through those particular numbers at your FTP with currect  out bound import format. Import rule will import those number at dialer.
I thik it will work.
Best Regards
Sultan Al Arif
+8801610005883
Overall Rating: 5 (1 ratings)
Correct Answer
arifsultanal Wed, 02/24/2010 - 03:44
Best Regards
Sultan Al Arif
+8801610005883
Related Content
