callmanager 7 SEP*.cnf.xml files PATH
Feb 24th, 2010
I need to see the files "SEP*.cnf.xml" on callmanager 7.x, but I don't know there locatio path!!!
1) I logged in via GUI and SSH and executed the command "files list tftp ." but in either case the ip phone files weren't there.
2) In the callmanager I also executed the following steps:
     a) In the "System" -> "Service Parameters", I selected the CCM and the "Cisco TFTP (active)".
     b) I selected "Advanced" an in "Clusterwide Parameters(Parameters that apply to all servers)" I set the parameters as follow:
           - Build CNF Files : Build All
           - Enable Caching of Constant and Bin Files at Startup : False
           - Exit When Exception is Caught : False
In both cases I can't see the files. Where are the files? Am I missing something?
Élio Fernandes
Aaron Harrison Wed, 03/03/2010 - 08:11
  • Community Spotlight Award,
    Member's Choice, May 2015
I have no idea!
What I would do is grab the file from the TFTP server as the phone does:
From the command prompt on a Windows machine, type:
tftp get SEPxxxx.cnf.xml
If will download it to the current directory...
Aaron
Please rate helpful posts....
