CUPS 7.x Requirment for VMware
Answered Question
Feb 24th, 2010
Hello, I am trying to find out what are the requirement to install CUPS 7.x on VMware. Are there any special setting while creating a VM machine ( RAM SCSCI etc) Setup failes after few mintues and it says ( No vaild devices have been found to ceate a new file system). Attaching a screen shot
Sam
Correct Answer by htluo about 7 years 4 months ago
What VMware edition you're using?  I have tested CUPS on ESX 4 and ESXi 4.
Also, make sure you choose the following:
OS: RedHat Enterprise Linux 4 (32-bit)
Memory: 2G
Hard Drive: 75G (LSI SCSI).
Hope this helps!
Michael
http://htluo.blogspot.com
Overall Rating: 5 (1 ratings)
Correct Answer
htluo Wed, 02/24/2010 - 08:18
  • Red, 2250 points or more
Memory: 2G
Hope this helps!
Michael
samaykhan79 Thu, 02/25/2010 - 03:23
Yeah I was looking at the old config of CUPS VMware and SCSI should be set to LSI type. I will try again later today and post a final update.
Thanks again for input
samaykhan79 Mon, 03/01/2010 - 05:46
Finally it worked with the above settings. Thanks for the help
Related Content
