VPN : Reason 442 - on Virtual Machine
Feb 24th, 2010
I have an HP laptop with Windows 7 (64 bits) installed. And I learned that Cisco VPN client is not supported for this operating system. So, I set up a virtual machine using VMPlayer (http://www.vmware.com/products/player/) and installed Windows XP Professional (32 bits). I installed Cisco VPN Client, Release with success.
When I tried to login into a network I got an error "Reason 442: failed to enable virtual adapter". I searched about it and found this on Cisco site (http://www.cisco.com/en/US/docs/security/vpn_client/cisco_vpn_client/vpn_client500_501/release/notes/51client.html#wp1584552) but I'm using Windows XP Professional and could not find the way to apply the solution provided (the solution is for Windows Vista).
I understand the problem is related to IP adresses but not getting a clue how to resolve it.
Please help me out over this.
sam141425 Thu, 02/25/2010 - 05:58
..I didn't know that it's so complex issue that no one responded. I believed Cisco community would be the best place to get the help.
Please respond.
busterswt Fri, 02/26/2010 - 18:33
Cisco has released a 64-bit IPSec VPN client that is currently in 'beta' status. I believe this became available on or around Feb 18th. If you have a current support contract and a CCO you can download this client on the support site. It's available under the 5.x All Releases folder in the '5.BETA' directory. It's version 5.0.7. Remember, it *is* in beta status so results may vary.
Check this out:
The Cisco VPN Client for Windows Vista and Windows 7 does NOT support the following:
* System upgraded from Windows XP to Vista or Windows 7 (clean OS installation required).
* Start Before Logon
* Integrated Firewall - See workaround below.
* InstallShield
* AutoUpdate
* Translated Online Help - Provided only in English
The 442 error in your VM can be caused by many thingss, which is likely why you haven't received a quick response. Try the 64-bit client on the native host OS and see if you have better luck.
heisman Wed, 10/06/2010 - 13:27
Hopefully you have this issues resolved by now, but I'll respond in case anyone else runs
into this.  I had been getting the same error message while running the Cisco VPN client
versoin on Windows 7.  I found that by disabling (ICS) Internet Connection Sharing
it fixed the problem.
