paolo bevilacqua Wed, 02/24/2010 - 07:32
  • Hall of Fame,
    Founding Member
You need to ask your ISP if they use PPP or not. And if the don't, if bridged our routed encapsualtions (generally is first, preferrable is the second).
In any case, you can enter "ADSL configurazion example" in the search box topright corner.
Correct Answer
paolo bevilacqua Wed, 02/24/2010 - 07:51
  • Hall of Fame,
    Founding Member
Enter "ADSL PPPoE example" in CCO search box, click first hit.
rogerio.mitsuo Wed, 02/24/2010 - 09:28
The problem is that my router 1841 have only interfaces fastethernet and not ATM. Thanks
paolo bevilacqua Wed, 02/24/2010 - 09:35
  • Hall of Fame,
    Founding Member
Enter "ethernet pppoe example" in CCO search box, click first hit.
