Configuring FAC on CME 7.0 for UC520
Hi All,
Can FAC(forced authorization codes) be configured on cme 7. I have checked some guides and I have not seen anything thing. Any ideas?
Also can UC520 cme 7.0 support centralised multisite configurations? The remote sites will be using voip pass through since there is no voice gateway. In terms of codecs all calls will be g711. Any feedback will be great.
Hythim Ali El Hadad Wed, 02/24/2010 - 09:09
  • Silver, 250 points or more
You can use "after-hours override-code pattern"  under telephony-service
Then configure your after-hours block pattern with this command: "after-hours block pattern pattern-tag pattern [7-24]"
Like that,block all your pattern all houre all days,then configure the patterns that will override this,then distribute this among your users
For your second ask: Do you mean having a CME in HO and registering a branch phone to it through WAN ?
If so,then you will need to ping the source ip add of the CME from the phone subnet,then i see no problem for registeration
Wish this be helpful
felixguzman Tue, 11/06/2012 - 07:53
Hello Jaime, can send account code via syslog server (FAC- service clid_authen_collect) ??
Regards, FGA
However I have tried this configuration using the following
telephony-service
after-hours block pattern 1 9 7-24
ephone 30
pin 555
I have also added the login software on to the ephone-template. However when I trying to access the login the softkey on the phone (521G) it is grade out. What can be done to resolve this?
Also what I have noticed is that all the patterns can be blocked for instance international, local etc however when i am applying a pin this pin will override all patterns? This is what i have read under the call blocking fetaure in the cme manual. Please advise if i have misread?
This is what i would like to accomplish
1. User calls a local or international number, the pin is prompted and when entered it will forward or deny the call.
2. Each user can use this pin on every phone thus not limiting an user per phone.
paolo bevilacqua Thu, 02/25/2010 - 13:19
  • Hall of Fame,
    Founding Member
You need a TCL/IVR script to do that. One like this come embedded with IOS, however does play any prompt.
