ASA currently managing the data network
Answered Question
Feb 24th, 2010
  • Bronze, 100 points or more
Hi all,
Need some advice on the outcome. Currently there is an ASA5505 managing the data network via a single subnet. Servers are plugged directly in and the switch serving the workstations is plugged in. All devices are on the 192.168.20.0 network. It is our idea that we will plug the switch into the expantion port of the UC540 and then plug from the LAN side via access port of the UC540 into the ASA. Are there any potential problems that would occur with CCA or the design?
Stephanie
Correct Answer by Steven Smith about 7 years 4 months ago
In CCA, turn of Data subnet DHCP.  On the ASA, have routes to the voice and cue subnets.  On the UC500, have a default route pointing to the ASA.  If you do that, you should be fine.
Overall Rating: 5 (1 ratings)
Correct Answer
Steven Smith Wed, 02/24/2010 - 10:09
  • Gold, 750 points or more
SHeidemann Wed, 02/24/2010 - 10:11
Very nice. Should be quick and easy.
Thank you for the input
Stephanie
