BGP -route filtering route-map
Feb 24th, 2010
Please see the following configurationin regard to BGP
IP access-list std pune
deny 10.1.1.0 0.0.0.0  ( exact mach for 10.1.1.0/24 )
permit any
route-map back permit 10
match ip address pune
router bgp 100
neighbor 192.168.1.1 remote-as 100
neighbor 192.168.1.1 route-map back out ( aggrigate route stopped to 192.168.1.1 neighbor )
aggregate-address 10.1.1.0 255.255.255.0 ( aggrigate route to all neighbors )
network 10.10.2.0 mask 255.255.255.0  ( local network )
Adv networks to 192.168.1.1 are :
Router#sh ip bgp nei 192.168.1.1 ad
BGP table version is 67, local router ID is 10.10.2.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 10.10.2.0/24     0.0.0.0                  0         32768 i
Total number of prefixes 1
This is expected : 10.1.1.0 /24 is blocked .
But now if I add second statement in route-map back as follows
route-map back permit 20  :    Weh this line is added it starts advertizing even the blocked network ( 10.1.1.0 /24 as seen in the following
output )
BGP table version is 81, local router ID is 10.10.2.1
*> 10.1.1.0/24      0.0.0.0                       100  32768 i ----------------------------> ( why this subnet is adv. even though it was blocked in first line )
Total number of prefixes 2
Adding second line to route-map is negating the block action in the first line ? Is it because the same subnet is aggregated here in this case
10.1.1.0 /24 ?
Please share the experience.
Subodh
Giuseppe Larosa Wed, 02/24/2010 - 12:06
Hello Subodth,
it is probably the logic of the route-map that allows for this.
if you would use a different route-map like:
access-list 11 permit 10.10.1.0 0.0.0.55
route-map block10 deny 10
match access-list 11
route-map block10 permit 20
in your route-map the 10.10.1.0/24 prefix is denied in an ACL , that is then used on a permit route-map statement.
so net 10.10.1.0 is not removed from the list of possible prefixes to be advertised, and it is then permitted by second route-map block.
using a deny route-map block should allow to put the prefix 10.10.1.0/24 in a sort a waste bin and does not leave it available to be permitted by a later route map block.
Hope to help
Giuseppe
