Logging in Agents
Answered Question
Feb 24th, 2010
What criterion determines which CTI Sever (7.1.2) a CTI OS agent logs into for a duplexed system?  I have done a ton of tests and can report with 100% certainty that it is not round robin and does not balance out perfectly even.  If there is a formula or a test the desktop runs while logging in could someone please share it with me?
Correct Answer by Edward Umansky about 7 years 4 months ago
There is no formula, it's just random. If you want to implement a formula you would need to manipulate the connection settings in a customized desktop, however that would likely break the built-in failover mechanism.
Overall Rating: 5 (1 ratings)
brian-peterson Wed, 02/24/2010 - 13:58
As a follow up I've found some evidence that suggests if the last octet of the client IP address was odd then it would log into CTI OS A and if even it would log into CTI OS B on first attempts. This does not explain why after logging in and out on multiple occasions the system chooses to switch sides.
Please, if anyone has any information, feel free to share.
Correct Answer
Edward Umansky Wed, 02/24/2010 - 16:31
  • Silver, 250 points or more
Related Content
