PIM BIDIR & PIM SM
Feb 24th, 2010
I have an Edge router which has a PIM SM domain
on the LAN interface and PIM BIDIR on teh WAN interface.
I need to be able to pass the multicast packets from one domain to the other.
Is there any way to do that?
Giuseppe Larosa Fri, 03/05/2010 - 01:23
my understanding is that a multicast group is treated as PIM SM or PIM BIDIR on the basis of the multicast group address, incoming  interface does not play a role in this.
The router can have a range of multicast IP addresses treated as bidirectional other as SSM other as PIM SM.
so I think it is not possible in the terms you are describing, it may be possible between two different multicast domains using MSDP between edge devices.
on a single device all you can do to emulate multiple devices is to use VRFs and multicast VPN and a physical link between one port in GRT and one in VRF where they speak MSDP.
But it is something that is should be tested and using a VRF may impact on unicast traffic.
Hope to help
Giuseppe
