Voip Monitor Server
Feb 24th, 2010
Hello I need to know what is neccesary to configured the voip monitor server in crs 3.5 in the second NIC? The second NIC is neccesary that this in vlan specify o IP specify when is used RSPAN?
Anthony Holloway Wed, 03/03/2010 - 20:21
was 3.5 a typo?  and you're just now getting around to setting up voip monitoring?
Did you check the install guide?
EDIT:  For comparison, in CCX 7, you enable the second NIC, give it a non routable IP, like, run postinstall.exe and choose the appropriate NIC as your voip device, and boom, your done.  Maybe 3.5 is the same.  I wouldn't know though.
