Redundancy IPCCX version 5.0.X
Feb 24th, 2010
  • " /> Participante em Destaque,
    Prêmio"Escolha dos membros": novembro de 2014
Hi Guys,
Another vendor did the implementation IPCCX Express version 5.0.X and after to do the Window maintenance I verified that the redundancy didn´t work. Are there the specific configuration to do in IPCCX to redundancy to work? I verified that when I disconnect the cable The IPCCX Principal the IPCCX Backup work. This behaviour is normal? The redundancy only work when there is physical down the IPCCX Principal?
Wilson Santana
Anthony Holloway Wed, 03/03/2010 - 20:27
  • Purple, 4500 points or more
If it's a network issue, then no, the Engine will continue to think that it's the master, and the secondary node will then elect itself master.  They call this island mode.  A proper failover scenario is when one engine stops/crashes, and the other node detects this, then the secondary node becomes master.  When the primary node recovers, it remains inactive until you force it, or the secondary engine stops/crashes.
If in the Control Center you see both nodes listed, then more than likely the vendor set it up correctly.
