Ping and Trace problem
Feb 24th, 2010
Vlan 70 and vlan 83 exist on 6513 floor switch 1 . This floor switch is tied to core switch 2. I have attached a Diagram of the scenario.
SVI for vlan 70 and 83 sit on Core 1.
My workstation is on vlan 70 and when i do a ping to a workstaion on vlan 83 it works but when i do a trace to the  same desktop on vlan 83 it stops on Core 1  and i dont see the trace going to hte workstation
Can anybody explain why this is hapenning.
gurkamal01 Thu, 02/25/2010 - 05:35
Hi Ediison,
"No IP unreachables " is not enabled on any of the SVI's
gurkamal01 Thu, 02/25/2010 - 06:12
I can ping the Workstation but trace doesn't work
i have question aren't ping and trace both the same (ICMP)
KARUPPUCHAMY MA... Thu, 02/25/2010 - 06:19
ping is working with ICMP and trace is working with UDP packets.
can you check is there any desktop firewall in your both workstations.
regards
karuppu
milan.kulik Thu, 02/25/2010 - 06:40
Cisco trace is using UDP but Microsoft tracert is using ICMP.
The difference between Ping and traceroute then is the traceroute works with TTL - it sends packets with TTL=1, 2, 3,...
And the routers on the path are replying with ICMP "TTL expired" responses.
The target device should respond with a different ICMP message (Host unreachable, I think) though.
BR,
Milan
gurkamal01 Thu, 02/25/2010 - 06:57
you mean if i can ping the workstation the firewall is stopping trace packets (UDP)
Is this possible?
